Not having a whole lot of people interested in buying my 88mm so now I am starting to rethink the valley charger.
I had my stock turbo machined out for a 68mm compressor, has been sitting in a box since. Other than the 68mm compressor, the turbine side is totally stock.
I am curious how it would react with the 88mm (88/112/1.23ar) basically a gt5518.
I could care less if the truck goes faster than it already has. I know it isn't an ideal match in turbo sizing but if it will work I'd definitely like to give it a try and eventually swap it out for a stg2r.
What got me curious is I saw Harbin run very impressive times with a totally stock lmm turbo in the valley. I just feel like my compound setup is very under utilized and if i can get the same work done with a smaller setup whether it be the atmo or the secondary, I'd be all over it, and considering I already have the 68mm stocker it makes it easy to justify doing.
