Pulling tomorrow one last ?
Huntinducks82
Apr 21, 2008
422
41
Centerville MD
I am running baja claws 33/17 they are about half worn down. My ? is how much air do you all think i should run in the back tires i know to let the fronts down pretty far but not sure about the back. The track has some grip but its not real hard.
Huntinducks82
Apr 21, 2008
422
41
Centerville MD
Tuchahoe steam and gas is havin a pull come on down its on rt. 50 like your headed toward easton from 213. Okay that what i will try thanks for the help.
bullfrogjohnson
Big Girl!
Nov 20, 2006
4,167
Locust, NC
60 in the rear depending on the track. If it is kooking real good I would go more air so you dont get alot of bite. But if its loose I would go with 50-55.
You can never go wrong with 60 psi in the rear
Good luck:D
Huntinducks82
Apr 21, 2008
422
41
Centerville MD
Okay so i ran 60 psi in the back and 20 psi in the front. I was the first puller and pull 291ft that would have been 3rd place. But i turned it down and only pulled 277ft the second time i think that was 6 or 7 place. But oh well live and learn i just cant figure out what the difference was.
Huntinducks82
Apr 21, 2008
422
41
Centerville MD
No i was not hanging weights i had 500lbs in the passenger floor board and maybe 250lbs in the bed and that put me to almost 8000lbs which was the class limit. The class i was in you could not hang weights.
