Well, I got all the parts installed this weekend. The main problem I am now seeing is I'm having a very hard time greasing the Tie rod ends. I can't really tell if any grease is actually getting into the ends, but if I don't hold the grease gun on the zerk fitting, it blows off from the pressure pretty much immediately. Even when I hold it, the grease squeezes out from between the zerk fitting and the guns adapter, and eventually is forced off the zerk fitting. Had no issues greasing the Moog parts (Upper and lower ball joints), or the pitman arm, which I discovered appears to be pre-charged with grease as a pump and a half in it started spewing a greenish grease.
Has anyone else had issues greasing the Kryptonite tie rod ends? I did note that the orifice on the zerk fittings on the tie rod ends seem to be 'noticeably' smaller than that on the moog parts. Should I go grab a zerk fitting kit and replace the fittings on the tie rod ends?
Aside from that issue, the front end seems MUCH better now. Prior to starting, the passenger side tire had a ton of play, probably due to play in the centerlink due to the idler an pitman arms. The Kryptonite idler arm and idler arm support seem orders of magnitude better than the stock parts... I can't see how you'd get ANY cenerlink roll with them.
The down side of this evolution is in the processes, I found I think I'm going to need a new front differential . Got play in the drivers side output.
