So, a year and a half later, have we made any huge earth-shattering mind-blowing breakthroughs in head porting that the rest of the Duramax world needs to know about yet?
Nope! Dont look like it.
You are right and I applaud you for trying to make a difference. My earlier comment wasn't directed toward you as much as it was for Ben. Maybe you can find a cheap difference maker although unlikely as it will be but keep trying.For anyone pondering, when do we stop with roof taper approaching the bowl? is there an excessive angle we must not reach? Is it the same for horizontal tapering?opcorn:
Also
Could the drop in the runner floor be explained yet? Its obviously mirrored from port to port and not a complete level floor to the short side. Could it be an attribute to keep a vortex minimally when higher rpms are used to help prevent reversion by high pressure 'bump' so to speak?
I remember Vizard saying something along these lines, don't direct the air where you think it is supposed to go but make some room where IT WANTS to go. Changing a valve design could make a difference in performance too. If someone does not think a loss in flow can happen with just a width change or angle change in a valve job (that is a physically TINY TINY AREA) then there is just the same amount of possibility within the runner itself, worth small or large gains.
Like Stingpuller mentioned he said something about 'running the same' as factory ported heads. Then what have we achieved besides an expensive piece of Aluminum?
