oil leak towards back of the motor lly
Teamvi
Oct 26, 2011
333
Is it common for the rear main seal to go out? I have a slow small leak towards the back of the motor, main seal or maybe oil pan? Any suggestions of what it might be? Pullin my trans soon but would like to order the parts before i pull it
thanks
Awenta
4,090
CT
Onto the top of the Trans and down?
Teamvi
Oct 26, 2011
333
I m at work, where does the turbo drain go? is it normal for it to leak or?
CaptPhil
1,012
Delaware
Turbo drain comes out of the bottom of the turbo and drains into the top of the block under the up pipe flanges.
CaptPhil
1,012
Delaware
How much oil drains from there?
All of the oil that enters the top of the turbo drains out of the bottom into a hard drain line, which drains into the top of the block.
It shouldn't be leaking externally, but oil coming from that area is commonly from that.
Awenta
4,090
CT
Depends how bad the leak is
Have you looked yet?
Teamvi
Oct 26, 2011
333
At work tell wednesday, i want to say the leak wasnt horrible, it would just leak a little down on the bottom of the tranny when i looked last, like in front of the pan
