dang Rob you were messing around when you told me you were re-wiring
What are you rewiring for?? Just to clean up the engine bay or what?
what the heck is the big block with the the four studs/blots sticking through at the front of the trans tunnel? Did all of those harness's reach as were or did they require splicing wire in to extend them?
Thats a grounding or power block, its been moved now tho, those must be older pics Tim.A lot of them had to be lengthened.
Im keeping my two large plugs under the hood next to the firewall so when i lift the cab its just a couple plugs. Im also running all my gauge wires through the two big plugs also. Im cutting the frount core support and mounting the Rad and IC to the frame so lifting the cab with the front clip is no hassle.
Im keeping my two large plugs under the hood next to the firewall so when i lift the cab its just a couple plugs. Im also running all my gauge wires through the two big plugs also. Im cutting the front core support and mounting the Rad and IC to the frame so lifting the cab with the front clip is no hassle.
The only one that I didn't lengthen or shorten, was the Underhood Fuse Block to ECM and TCM. Pulled those into the cab and to the Center Consol. I think that we stared at it for 3 days after pulling the wires into the cab and just shook our heads...LOL Did a systems check yesterday will all things plugged in and everything is reading and working properly. Now to just get everything else done...
This is where the Power and Ground are at Now. We used 2 Nice junction blocks for all of that.
Why retain all of the stock harness and fuses? You need a third of that. Looks like you could shave another 200 lbs.
