Off Season Sled Pulling Mods
JD Dave
In way over my head
May 19, 2008
2,388
Caledon, Ontario
TNRGreene
Kicked to the Curb
Sep 2, 2006
2,911
Bradenton, Florida
I need some belt routing help guys. I swapped to a van thermostats housing and don't know which way I need to go. Has anyone done this already with PPE dual fuelers and ac still intact?
This is what I have, not sure it'll help. Keep in mind that my CP3 location uses more belt. I had the pulley off & had the stock fan pulley in place & had it looped around the A/C "dummy" bracket for testing because I am putting A/C back on. Also you know there are different size pulleys? I went with 2 larger to make it work. Hope this help a bit :hug:
sweetdiesel
That's better
Aug 6, 2006
10,390
53
Thailand
Can you just flip your belt tensioner because that and the oil fill tube is all I see different from my truck. So I think it will work. I'm assuming the belt is a different length though.
Dave
No I doubt you could flip the tensioner that is a 01 notice the difference on todds pic
Also notice the pulley above the balancer on both mine and todds are both missing :)
Rhall
Old Skooler
Aug 12, 2006
2,241
42
Texas Y'all
I got them making me one, They triple weld them for the diesels app. I went with the I.C.3k They recommend 10-15 gal ice tank.
They build an awesome piece, they also pressure check them for free after the seasons over. I know they deal with gassers a lot, I think we burn more ice than them, might want to go a tad overkill.
durallymax
Apr 26, 2008
2,756
Under The Hood
Make sure you check it b4 u start it up. I got one that leaked :mad:
Well have to double check it after adding supports to it this year.
Also used Boost Braces, buddies or whatever they are called from Vibrant for holding the tubes on. They seem like very nice pieces, we arent running 100psi or anything crazy, but they do help support them nicely for a low price.
jimdmax
Feb 18, 2007
264
Garden Prairie IL.
Delete oil cooler - Remote oil filter pics.
Thanks Ed (05smoker)
05smoker
I'm officially done!
Mar 30, 2007
2,379
Lebanon, OH
That looks awesome! now this may be a stupid question but whats the advantage to remote oil filter? sides easier to change. :confused:
I run a Holley Oberg style filter on mine mounted to the frame rail just under drivers door. Allows me to pull the screen and look inside after any run.
sweetdiesel
That's better
Aug 6, 2006
10,390
53
Thailand
Thats so nice!!! No power steering? or is that a hydraulic pump?
I love where you mounted the alt
attachment.php
Rhall
Old Skooler
Aug 12, 2006
2,241
42
Texas Y'all
So have you checked to make sure the screen is not siezed up? Doesnt sound like its been pulled out much?:roflmao::hug:
