Off-Brand Vibrant PCV Scavenge Fittings
Bdsankey
3,910
1,074
Neenah, Wisconsin
Does anyone have any experience with these evac fittings? https://www.amazon.com/gp/product/B07J69G4YN/ref=ox_sc_act_title_1?smid=A17PPRRJETTLJ1&psc=1
I am looking at installing a Vibrant catch can (4 port, closed system) and running the lines into the exhaust. This post is not a "will it work" thread (we know it does), this is more so a post to determine if these off brand fittings work as well as the vibrant ones or if I need to scour the web/ebay to find genuine vibrant fittings.
MAXX IT OUT
<<<IT WORKS
Mar 1, 2013
1,774
Des Moines, Iowa
How much vacuum does the Vibrant fitting or these style pull? I am thinking about in installing 1 or 2 in my new down pipe, but not sure if its any better than my current vented catch can.
Bdsankey
3,910
1,074
Neenah, Wisconsin
That I don't know, but I do know it is more than atmospheric pressure in regards to it *should* hit negative (vacuum) as opposed to just 0psig. I'm planning on putting 2x of these in my lower downpipe half as well as in a customers LLY I just wrapped up.
4,955
generally -1 to -2psi is what ive seen/found. higher the exhaust velocity, the more you gain from it. 2 hoses/venturi's seem to work best as well so either one from each valve cover or a large catch can with two breathers in from the valve covers back to 2 breathers out.
Bdsankey
3,910
1,074
Neenah, Wisconsin
Thats the plan, just wanted to make sure these fittings are decent. I know vibrant one are what have been used/discussed but are no longer produced.
I figure 2x -10 hoses should be sufficient as that is what is on the catch can (I don't recall what my merchant PCV reroute fitting size is but I'll make it work). Plan is to weld the fittings in the downpipe just after the bend to point rearward as it should have good velocity and still keep heat. Putting them before the bend I am worried about a potential backup/not as high of velocity.
gmc502
463
12
think you could weld these in to the up pipe and let the hotter exhaust gas burn up the oil fumes?
coker6365
Coker6303's ***** Daddy
Dec 4, 2011
486
I know other have had luck with these, however, I did not. Had a 1/2" in the original downpipe and it actually created positive pressure and back fed exhaust soot to the valve covers. Rocker area looked like oil/soot mixture when we pulled the heads.
Maybe 2 1/2" fittings will work. We just run our to atmosphere now and everything was spotless when we pulled heads this time.
Sent from my SM-G965U1 using Tapatalk
4,955
not unless you want to pressurize the crank case. Up pipes are under positive pressure the moment you start to come on boost (actually before boost comes on but close enough).
4,955
you had the venturi put in at the same angle as the slit at the end of the nozzle? was it facing correctly inside? if its not put in right, it will add pressure to the system and if there is any back pressure in the exhaust, it will do the same.
coker6365
Dec 4, 2011
486
I will have to look, that downpipe is on the shelf. And it may have been some sort of off brand contraption since it was already in the downpipe when we pieced together the kit. My situation has a lot of variables I am sure. We just simply went to atmo with it and done.
Bdsankey
3,910
1,074
Neenah, Wisconsin
I don't think I'll have back-pressure issues with the 4" and including how short it is before the stack.
My only concern with this is potentially getting flagged at the local track. Friend of mine's Cummins got flagged and told he had to have a catch can (it wasn't puking oil either).
gmc502
463
12
thanks for reminding me about drive pressure,,brain farted on that one.:D
WolfLMM
Making Chips
Nov 21, 2006
4,005
25
AL
Exactly, and yeah diesel exhaust is slow, so they do work but not very well. They’ll pull nice vacuum on a NA gas engine.
WolfLMM
Making Chips
Nov 21, 2006
4,005
25
AL
I did too. The problem is diesel exhaust is too slow. I had much better results just venting to atmosphere. We all know the physics behind the design, but sometimes the practicality of them come into question. I too just vent to the atmosphere now. Simpler and works every time. Jmo
Bdsankey
3,910
1,074
Neenah, Wisconsin
Good to note. I need to do something as just running a hose to the ground is going to get me flagged at the local track as they believe it is a safety concern.
DuramaxRamRod
138
11
NH
But what about the flow through the up-pipe? Its not deadheaded so it shouldn't push into the crankcase.
Bdsankey
3,910
1,074
Neenah, Wisconsin
It's physics at the end of the day, air/fluids (air can be analyzed as a fluid) will always flow from high pressure to low pressure via the path of least resistance. The crankcase is under MUCH less pressure than the up-pipes are thus the exhaust flow will try and go into the crankcase via the lines ran to the up-pipes.
DuramaxRamRod
138
11
NH
But this is an evac/eductor type fitting. Besides pressure there is also velocity, which also plays a role in fluid flow. Otherwise eductors would not exist.
Bdsankey
3,910
1,074
Neenah, Wisconsin
I've never seen a fitting like this in a high pressure scavenge situation in an industrial setting. The other thing you will be doing is impeding flow in the up-pipe to a large degree.
