I've actually popped my safety valve a few times at a grand so I try to stay just under like 900-950.
Ok sounds good. What kinda bottle heater u run? I've gotta order one but nothing around to to look at.
Josh will right you tunes
Probably have to sign a waver for the stock engine nitrous tune lol
Get a bottle, line, solenoid, shark nozzle, a relay, and a momentary push button switch.
Get a multi-pack of jets from local auto parts store, they are cheap.
Start with a .050 jet and work up until the exhaust is clean at full boost WOT.
You dont need a special tune for nitrous use.
:thumb:
A nitrous specific tune/dirty tune does help but no its not needed
Or if you want a budget two stage: bottle w/brackets, line, three solenoids ,a WET fogger, three relays, a Hobbs act 15psi with a small jet, Hobbs act. 25psi with no jet and a push button for purging.
If what you mean by "dirty tune" is a low timing tune, then you're just wasting potential energy (hp). When you are at the limit of your hard parts' fueling capabilities you need to use what fuel you have as efficiently as possible. The nitrous is just used to add O2 that you wouldnt be getting otherwise from the turbocharger.
I wonder what max power has been made on stock lbz with spray?
Stock as in stock fueling and stock tune? Or just stock fueling?
We made 689 on a totally stock LBZ with a .125 noid and a .099 jet. It had a built trans and a lift pump. With no gas it made 507. I think it couldve gone over 700 if a lockup box wouldve been available back then.
