Hey ya'll. It kinda looks like the dealer is going to have to replace the piston rings on #4 and #8 cylinders on my 01 lb7. They will do the labor for free and I will be suppying the parts. I'm looking to buy just the rings for those 2 cylinders. I'm not sure if used rings can be used or not, but I don't have a lot of money, limited income ya know. Also looking for some of the other parts to put it back together, we are just pulling the drivers side head off only after pulling the motor. I guess I would also need head bolts, valve cover sealer, head gasket ( I know you have to know which thickness the old one was), and any other gaskets that will be needed.
If I cant use used rings, does anyone have new rings for 2 cylinders. I has a thread going: LB7: Lower compression on 2 cylinders only when cold!!!!!!! a few days ago about low compression in those 2 cylinders. It seems that it is bad rings.
The small dealer that is doing the work Is absolutely great about trying to help me. We both know that Its kind of their fault and Its kinda not their fault. Thats why I'm having to supply the parts.
ANY help would GREATLY be appreciated.
Thanks
Thanks
