Need Help!! Transmission Leak
Lparrill
And here we go again
Jul 30, 2010
445
9
Lander, WY
Can someone help me to determine what this little clip thing is and why its leaking fluid. Its turning into a pretty bad leak
Here's a picture with the red thing being the spin-on filter
Thanks
Lparrill
Jul 30, 2010
445
9
Lander, WY
The transmission hasn't been pulled apart to my knowledge
Is there a way to determine if it is the seal leaking or the converter is leaking without pulling the transmission?
Thanks for the replies
blackdirtymax
Apr 15, 2010
825
augusta, ga
no i don't believe so, reason i asked if it had been out is because you can also get a leak from the bolts behind the converter going into the pump. I have seen leaks from that as well . Either way your gonna have to pull the trans
rossi
Jun 10, 2009
24
have the same problem on my 04. Mechanic says that it a leaking gasket and while I am at it may need to change the pump.
Bonestock
1,358
Worland Wy
Trans
I have done a few of those jobs. Pull Trans replace Front Seal and Bolts around front pump along with oring around pump. Also when you have T-case out think about the pump rub fix if you have not done this. Make sure you replace the front seal on T-case once you remove it for the trans job.
