More Help please
You posted on Diesel Place that this condition occurred after reflashing your truck with EFILive. First suggestion is to reflash your stock tune back into the vehicle to determine if it's tune related or truck/mechanical related.
Cheers
Cindy
chops3131
<---JUST SAY GO
Jun 24, 2008
117
42
Nederland Texas (South East Te
Summary
Supported parameters available 115
Validated modules available 7
System readiness test (EPA) Not checked yet
Specifically monitored tests Not checked yet
O2 sensors tests Not checked yet
Diagnostic trouble codes Detected
History freeze frames Not checked yet
Stream-Slow scan mode Supported
Stream-Fast scan mode Supported
Maximum dynamic packets 8
PCM
System Readiness Tests Results
Specifically Monitored Systems Tests Results
Oxygen Sensors Tests Results
Diagnostic Trouble Codes
P0380 "Glow Plug Feedback Circuit A" EPA ($10) "Powertrain Control Module (PCM)"
P0489 "Exhaust Gas Recirculation (EGR) Solenoid Control Circuit Low Voltage" EPA ($10) "Powertrain Control Module (PCM)"
P2141 "Exhaust Gas Recirculation (EGR) Throttle Valve Solenoid Control Circuit Low Voltage" EPA ($10) "Powertrain Control Module (PCM)"
P2144 "Exhaust Gas Recirculation (EGR) Vent Solenoid Control Circuit Low Voltage" EPA ($10) "Powertrain Control Module (PCM)"
P2227 "Barometric Pressure (BARO) Sensor Performance" EPA ($10) "Powertrain Control Module (PCM)"
P0101 "Mass Air Flow (MAF) Sensor Performance" EPA Pending ($10) "Powertrain Control Module (PCM)"
P0380 "Glow Plug Feedback Circuit A" EPA Pending ($10) "Powertrain Control Module (PCM)"
P0489 "Exhaust Gas Recirculation (EGR) Solenoid Control Circuit Low Voltage" EPA Pending ($10) "Powertrain Control Module (PCM)"
P2141 "Exhaust Gas Recirculation (EGR) Throttle Valve Solenoid Control Circuit Low Voltage" EPA Pending ($10) "Powertrain Control Module (PCM)"
P2144 "Exhaust Gas Recirculation (EGR) Vent Solenoid Control Circuit Low Voltage" EPA Pending ($10) "Powertrain Control Module (PCM)"
P2227 "Barometric Pressure (BARO) Sensor Performance" EPA Pending ($10) "Powertrain Control Module (PCM)"
P0380 "Glow Plug Feedback Circuit A" MPH ($10) "Powertrain Control Module (PCM)"
P0489 "Exhaust Gas Recirculation (EGR) Solenoid Control Circuit Low Voltage" MPHC ($10) "Powertrain Control Module (PCM)"
P0522 "Engine Oil Pressure (EOP) Sensor/Switch Circuit Low Voltage" PHC ($10) "Powertrain Control Module (PCM)"
P0530 "Air Conditioning (A/C) Refrigerant Pressure Sensor Circuit" PHC ($10) "Powertrain Control Module (PCM)"
P1094 "Fuel Rail Pressure Low During Idle or Decel Fuel Cut-Off (DFCO)" PHC ($10) "Powertrain Control Module (PCM)"
P2141 "Exhaust Gas Recirculation (EGR) Throttle Valve Solenoid Control Circuit Low Voltage" MPHC ($10) "Powertrain Control Module (PCM)"
P2144 "Exhaust Gas Recirculation (EGR) Vent Solenoid Control Circuit Low Voltage" MPHC ($10) "Powertrain Control Module (PCM)"
P2227 "Barometric Pressure (BARO) Sensor Performance" MPHC ($10) "Powertrain Control Module (PCM)"
C0222 "Rear Antilock Brake System (ABS) Channel in Release Too Long" H ($29) "Electronic Brake Control Module (EBCM)"
C0221 "Right Front Antilock Brake System (ABS) Channel in Release Too Long" MPHC ($29) "Electronic Brake Control Module (EBCM)"
C0225 "Rear Antilock Brake System (ABS) Channel Motor Free Spins" MPHC ($29) "Electronic Brake Control Module (EBCM)"
C0226 "Left Front Traction Control System (TCS) Channel Will Not Move" H ($29) "Electronic Brake Control Module (EBCM)"
B0026 "Left Front/Driver Frontal Deployment Expansion Control Circuit" H ($58) "Inflatable Restraint Sensing and Diagnostic Module (SDM)"
U1000 "Class 2 Data Link" HC ($58) "Inflatable Restraint Sensing and Diagnostic Module (SDM)"
History data
SmokeShow
6,818
Lawrenceburg, KY
If it helps, here is a copy of my stock tune as well. It's on 02. I don't have efilive on this computer anymore so I couldn't see if Steve's is the same as mine or not. If it helps, great. If not, sorry. :(
  • Copy of MITCH STOCK TUNE 012707.tun
LarryJewell
Back with his honey :)
Jan 21, 2007
10,152
58
San Angelo
truck # 1 and # 2 are running either the Edge or Banks, are you using these in addition to EFI live:confused:, if so, try ditching the edge and/or banks and see if the problem is still present
Feb 14, 2009
110
50
I don't know much about EFI, but, do you have a lift pump? If this is only happening with excess fuel demand at higher RPMs, and again at start up with a tune already loaded, could the demand for fuel be too much for the CP3 to push causing the low fuel rail pressure problem?
