Explain in idiot terms what and why you are using lly vanes? Also could you use a 4094 cartaidge with an lly exhaust housing?
Ok so I just typed up this nice response and this stupid tap a talk wanted to be stupid and never sent the stupid thing so I'll give you the short and sweet. Russell has by far the best customer service of anyone I spoke to about turbo work. His port and polish is a true port and polish and not just a piss poor gasket matching. For the machine work on going 72mm, the billet wheel, port and polish, hx40 machine work, complete rebuild with upgraded 360* thrush bearing, balance of rotating assembly I think I'm in it for 1400ish in the turbo only. ThaTs a great price considering the time invested.
Looks sexy man!Finished the porting/polishing of the exhaust housing. Need to do a finally cleaning, blasting, and some paint.
Got it all painted up, turned out good.
Got the cover and 72mm wheel back from getting machined. Really excited to see how she does!!!
Yellowchevy
What is the wall thickness between the exhaust housing inside bore diameter and then the housing outside diameter at its thinnest area? It looks thin but just wondering if you have any concerns about the downpipe flexing and causing the housing side flange to crack and break? Not trying to insult the work or anything but im just curious cus this seems like a great mod for these turbos and would free up some space behind the motor im sure with the bend in the downpipe.
I second this quote ^^
Russell, if I had you open up the exhaust house to an hx40 on my LBZ stocker you p&p'd. And running it with an s480. Would there be any negative effect with lag or anything else?
Would you say that this is a worth while mod if one has access to equipment? I would definitely like to try this out.
