Main seal installer
Evan@InglewoodTrans
yerp
3,118
65
Western MA
Has any had any luck installing the front and rear main seals without the GM tool? I can't see spending the money for something I would almost never use but if I have to I have to.
TrentNell
Finally underway !!!!!
Jul 7, 2008
7,543
slc tuah
I built my own , and have installed at least 20 of them with out issue . But you have to have a way to make a "ring" with the right ID / OD , lathe , plasma cutter , or even a torch could work if you cut it big and ground by hand to get it the rest of the way . after you have the rings I just welded some exhaust tubing to it with flat bar across the other end for a area to strike .
dmaxx3500
Jul 26, 2009
chicago
get a piece of pipe the same size as the metal lip on the outside of seal and tap it in,if it goes into the outer cover then a piece of wood works too,lay the outer cover flat and tap it on
