Hey! I have a chance to get a couple of heads from a 01 lb7 that in one of the injector holes, where the cup seals at the bottom is a slight bad spot where when the injectors were replaced , the cup moved slightly. This must have let a peice of dirt get under the cup and later got blown out and caused a slight anti-freeze leak. Question, is there any way to machine that bottom surface so that a new cup will seal again and make that head usable. It probably only needs 1or 2 thousands taken off the bottom of the injector hole in the head to make it seal and keep the anti-freeze from leaking into the cylinder. Any help would be appreciated.
Thanks, Rob
Thanks, Rob
