Recently a board member exploded a 275/60-16 M&H drag radial on the street, and we exploded one using it as an emergency spare to get to the next off ramp in Utah.
I would not recommend running these on the street except for short distances. Make sure you run them at correct max pressure if you do. If you see a lump forming on the tread, or get vibration from the tire, discard it.
We have taken these tires up to 128mph at the track many times, and have run them on a 6800lb truck with no issues. They are excellent drag tires. But sustained freeway speeds might overheat them and cause ply separation.
