lowered truck rancho 9000?s
zf>allison
you never had your car.
Apr 30, 2013
3,394
elsberry mo
Ok I've done some reading and it seems I have gotten alot of part numbers including stock length shocks, which may be fine but that's another question. Are stock length shocks fine for a 3 inch drop truck slammed t bars without prematurely wearing them out? I want something I don't have to modify to bad busching wise or bolt size. And I don't want them.to bottom out. So does anyone have a number or at least a length and bolt hole diameter I should be looking for?
zf>allison
Apr 30, 2013
3,394
elsberry mo
That's what i was gonna do. I know alot of guys racing use em. Got to be better than 4 blown stock shocks. I have a really bad lifting problem off the line. I can cut a 1.8 60ft. I think shocks would help alot.
Hernpj01
On a Time Out
Sep 23, 2014
403
Indiana
i think so, plus you have full adjustment with the 9000 series i have bilsteins now think im going to swap them out for some ranchos first of the year. Looks like i will just order for stock height(front and rear) im -2 in rear.
OregonDMAX
NOT IN OREGON, NO DURAMAX
Apr 28, 2013
3,964
37
Goodyear, AZ
I found 2" lower ranchos on amazon, I had to play with part #'s and the "will this fit your vehicle" nonsense but I got what I wanted.
OregonDMAX
Apr 28, 2013
3,964
37
Goodyear, AZ
RS999029 and RS999113 for 2" lower front an rear.
the rears either have to have different bushing metal bolt sleeves put in or run without the sleeves because the ones it comes with don't work. I'm assuming the reaos are for a NBS but I don't care I just went with no bushing metal bolt sleeves and they are fine. The bushings just might wear a little faster
zf>allison
Apr 30, 2013
3,394
elsberry mo
where did u pick those up?
^^oh amazon^^
smkndmax05
"Smoked Out"
Feb 17, 2011
479
Indiana
Stock height rancho 9000s all around.
