ya ok good luck with that thought to many yrs working on diesels
talked to quite a few guys that had that problem, changed cups, did it right and no more pressure,
also just a side not IT RAN TODAY, last sat i broke my bleeder screw and didnt have the right size so i think i was suckin air in, but today i got the right size and cut it down to size and it worked great, and i had to prime w the key on, haha maybe i just got lucky but my buddy came over and we decided to try it, got it primed, cracked lines at the end of each rail rolled it till we got fuel and hit it w/ a bit of ether she lit right up,
down side to all that, it ran good for a couple minutes, i shut it down to finish it up, put the belt on all that little stuff, fired it again, this time just w/ rollin it over but it took a little longer then it should have, smoked a bit not bad, backed down the drive noticed the smoke was pretty heavy, kinda black haze, so i took off down the road and smoke stayed, got 1/2 mile stopped at a church to turn around and she was lopin hard, and had the pulling truck smoke lope thing goin on, so i headed home, and she kept smokin, if i took off it smoke black a decent amount, got it home, it was lopin real hard and smokin bad at idle, then it kinda started a knockin sound or a bad bad miss, so i shut her down, but while running i realized i had major blow-by, i mean major, tried a couple things nothin helped. tighted the injector lines i could get to went to try to restart it and nothin, wont start, hit it w/ ether she fires right up, idles great for a second then goes into that huge lope,
the kicker is there is no codes, not a single one, so i think the dealer will give me what i want out of it and im gonna off this truck and try somethin else,
but before i do that, tomorrow im tearin down the to the vavle so i can re-tighten my injector lines, b/c i seen 2 have a bit of fuel building on top of them, and im tearin out the middle so i can replace all the rubber lines
im not worried about the miss im more wondering about the blow by, b.c nothin i did has to do w/ the crank case, unless i blew a hole in a piston haha, but it idles good for a sec so thats not it,
