Low rail pressure with dual fuelers
06dmax
Aug 5, 2009
295
Just got my dual fuelers on and it's constantly tripping the low rail pressure light could that be in the tuning?
06dmax
Aug 5, 2009
295
There all brand new injectors flow tested balanced everything I'll start by tightening the fprv
06dmax
Aug 5, 2009
295
On my way out to pa last night I was monitoring desired and actual when desired was at 23 actual was at 20
blk smoke lb7
<-----Lots of green $
Nov 8, 2010
5,694
57
belvidere,ill
I've seen new injectors pass fuel when I had 1 injector passing I was commanding 23000 and getting 17 18 Sometimes even 21 It doesn't cost anything to bottle test atleast you can eliminate that
06dmax
Aug 5, 2009
295
Rob did my tuning have to send him logs but I noticed as I accelerate desired will be 24 actual will hit like 21 and then start dropping from there it went down to 9.3 once it's all over the place
WisconsinHick1
Mar 11, 2009
1,231
Minnesota
Sounds like CP3. If it was injectors it would hold the pressure until you got to a certain throttle position. My pump would hold 26000the all day long at 75%the or less throttle one I went higher then 75%mine throttle rail pressure would drop like a rock. Found out injectors are shot.
06dmax
Aug 5, 2009
295
Now I just gotta figure out witch one how do I test the cp3 I'm still gonna do a bottle test too
