Logging Timing? Issues with timing being higher then requested.
Dozerboy
4,809
391
TX of course
Could someone confirm you can log Pilot and Post injection timing on an LBZ? The only pids I could In BBL find didn’t work.
I’m working on retuning for my new 100over injectors and am way over the requested timing. 10* higher then it should be. Never had this problem come up with stock injectors and I don’t see any timing injection corrections that should be making it this high.
Dozerboy
4,809
391
TX of course
Boy that was a lot of logging to figure out it was only the last modifier table. AAT. The first set of ECT No P1&P2 was changing the timing a little, but once I zerod out AAT it was right where it should be. Odd it was going anything. I’ve never seen it make any changes before. If you look at the multiplier I don’t even think it should make any changes until it’s 130°F, but for some reason it was when the AAT sensor was only reading 93°.
