LML Twins and Opinions
Dm23
449
171
Socal
Y bridge is out. Having trouble getting it out. We got the 3 pedestal bolts out. And the oil feed off coolant lines off. Something is still holding it in
Dm23
449
171
Socal
Is there another oil line to the right of the turbo. If your looking from the front of the truck ?
FROGMAN524
613
Man sounds like fun. Did you have to disconnect the oil drain line to get it out? Did you break the up pipe bolts loose from the fender wells from over the top of the front?
Josh154
1,220
85
Sioux Falls SD
I disconnected mine from the block and left it attached to the turbo and pulled it out together. Up pipe bolts I got from both fender wells and top
Dm23
449
171
Socal
Does anyone have a picture or something on how the rubber lines run. That are supplied with the cp3. I want to keep the factory fuel filter
Dm23
449
171
Socal
Ya, oil drain line had to come out. And to get to it, we had to go through the passenger fender well and use a long “breaker bar” so to say. Those are a pain in the ass to
Dm23
449
171
Socal
I’m installing a Danville 65mm onto my truck and I want to know where to put the new oil feed line on the block. Where is the oil feed on the block at ?
Columbus450
260
Louisiana
On a Lbz oil feed line is on the Passenger side of the engine block, There should be instructions with it
Sent from my SM-N960U using Tapatalk
Columbus450
260
Louisiana
Here
Dm23
449
171
Socal
There is a vague description that came with the turbo and it’s not clear or colored
FROGMAN524
613
Well my Danville 63.5 just showed up. I have two oil feed line kits and blocker plugd as they want me to use the oil gallery on the driver side of the block since my S480 is using the passenger one. Also came with a new VPS sensor as well. How can I “learn” the VPs or do I have to go to the dealer?
