LML-0087&CHANGE FUEL FILTER MESSAGE
Jfree
Aug 17, 2020
NePa
Deleted, efi live, fass lift pump!!
Every start up change fuel filter message appears and once driving normal or hard 0087 code. I’ve replaced filters, water in fuel sensor, service fuel filter sensor/switch, fuel pressure sensor, fuel pressure relief. No metal in tank or filter during fass install last week. Didnt cure code or message. Truck runs great all the time!!Stumped!!
ikeG
Oughta Know Better
Apr 19, 2011
2,429
128
Western PA
www.facebook.com
Watch actual vs desired fuel rail pressure on a scantool while getting it to set p0087. If it's low you may be catching a failing cp4 before it grenades. Did you replace the entire fuel filter head?
Sent from my SM-G960U1 using Tapatalk
