LLY Turbo Surprise
LBZ1991
Nov 21, 2014
215
Winfield, MO
Here recently I bought what I thought was a stock lly turbo to modify like a few guys have done. Well it showed up the other day far from stock. Pulled it from the box and it's got a 71mm billet wheel and the exhaust housing has been machined bigger. Then I found out it has a bent shaft. Long story short I need to figure out where I can get a new turbine to get it going. I've got some measurements in the pics.
Awenta
4,090
CT
Contact II. If anything see what they want for a rebuild.
durawhore
Aug 19, 2014
124
Where did you get the charger from? Maybe they could help you out.. thought the biggest wheel you could put in a lly charger was a 68 when I was looking at having one built by gds here in slc I was told there wasn't enough material in the stock housings to open them up that much
LBZ1991
Nov 21, 2014
215
Winfield, MO
Try checking with Dannville performance, maybe even if it isn't theirs, they could help you out.
I've called them. They told me to just send it to them. Didn't talk to mark though. So maybe I'll call back and see if he can give me some more in depth details.
