LLY DSP5 Out of Range
07nastymax
Native Pride
Apr 21, 2008
111
St George UT
I switched a stock lly tune file to dsp5 and all the custom calibrations are out of range...for instance one table has -500 for all the boxes and another has 5000 for all the boxes. I tried switching in the stock parameters and saved but it still says out of range for those tables as soon as I open the tune tool! Could it be the software version build?
07nastymax
Native Pride
Apr 21, 2008
111
St George UT
I dont understand the script part...I have not tried tuning it yet I just switched the stock tune file to the dsp5 and saved it to a new file. I then tried to open the stock dsp5 tune file and it takes me straight to the out of range tab. Unless I did not underatand what you were saying?
MMLMM
Tunergeek
Mar 2, 2008
4,086
42
Reno, NV
www.dyncal.com
upgrade the stock tune to dsp5.
Save it, close it.
Re-open it. Go to edit > configure display units > press "All" then hit "imperial" then hit "ok"
Go to Edit > Run Script, Click open then select DSP5_LLY_Imperial, then ok.
Then click Run.
Save as your blank dsp5 file. re-open and you will be golden. :thumb:
07nastymax
Native Pride
Apr 21, 2008
111
St George UT
Save it, close it.
Then click Run.
Thanks All!
Mike, I really appreciate you taking the time to explain the steps.
