LBZ TCM problem
BM06lbz
45
coon valley, Wisconsin
Howdy, so this afternoon I started my truck to go somewhere and randomly started having problems. My Speedometer stays at zero, my truck is stuck in third gear and I get three codes. The one code is P0540 The next code is P0405 and then the last code is U0101 (which is lost communication with TCM) right after it started happening I cleared the codes and every thing worked and shifted fine for about 3 miles and then it got stuck in third gear again and now I can’t get rid of codes. Also, another strange thing that happened is twice after I started it the truck stalled out and died. But then the third time it fired right up and I limped it home. So just curious what I should be looking into for the problem could it be a bad TCM?
Dozerboy
5,100
701
TX of course
I would look over the wiring first and make sure nothing looks damaged to the TCM. Maybe you can find a pin out and at least check power and ground in the TCM harness first.
3,559
Any reason why I can’t quick hookup my buddies TCM just to see if codes go away?
Because you may have had an issue in the power/ground leads that possibly shorted your TCM. Unless you want to risk your buddy's, too?
BM06lbz
45
Well, after really looking into the problem I decided to buy a new TCM. I got overnight shipping and threw it on yesterday. So far my truck‘s been running flawless . By the way, new TCM’s for these models of trucks are getting scary hard to find since GM discontinued them :(
