lbz lowered with airbags
sparepartsracing
spareparts offroad&fab
Mar 17, 2010
773
35
are there any companies that make air bags for lowered truck with goosenecks? or anyone done this before? i don't want full air suspension.
Novak
SQUIRREL TRYN TO GET A NUT
Jun 15, 2015
990
Cloud 9, IDAHO
Tyler at SDP hooked my friend up and his is lowered 3 inches and the overload spring is removed and and Tyler at screaming diesel hooked him up.
LBZ1991
Nov 21, 2014
215
Winfield, MO
I don't think there is a kit that will work with it lowered. I build a set of mounts for my truck as it has 3in shackle with the overload removed. I'll see if I can get some pics
OregonDMAX
NOT IN OREGON, NO DURAMAX
Apr 28, 2013
3,964
37
Goodyear, AZ
The bag will have to be mounted outside the frame rail instead of under it. Kits for a 1500 that mounts on the outside of the frame is all you will find that is bolt on but won't be the same as what is offered for a 2500
Awenta
4,090
The ford bags Mount like that. Shouldn't be too hard to retrofit
sparepartsracing
Mar 17, 2010
773
35
yeah i was hoping for any easy way out but, doesn't look like its going to happen. Thanks for the info everyone
clrussell
pro-procrastinator
Sep 23, 2013
6,034
527
Get a kit for an 99-02 dodge 3500.. have to drill holes but it'll work. As long as your wheels have stock offset at least..
I ran a set on my lowered Zf6
LBZ1991
Nov 21, 2014
215
Winfield, MO
Mine mount off the rear of the axle. Still requires welding and drilling but clears the bed hitch and my 5in exhaust. Think I have some extra brackets if you're intrested
sixsixkid1
On a Time Out
Jan 14, 2011
11
butler pa
There is a company called Timbren that makes a HD rubber bump stop for towing, I talked to them on the phone awhile back and they told me they didn't make a kit for lowered trucks but I could pull measurements and they could make something work. If you don't have to have airbags it's another option.
clrussell
pro-procrastinator
Sep 23, 2013
6,034
527
These are exactly what he needs.
I have a set I've never installed
sparepartsracing
Mar 17, 2010
773
35
Yes. Definitely interested.
sparepartsracing
Mar 17, 2010
773
35
I think that would be a really rough ride tho
Awenta
4,090
How heavy are you towing? Too much for air shocks?
sparepartsracing
Mar 17, 2010
773
35
Have a 40' gooseneck toyhauler with a 5600lb buggy in. Probably 20k total
05chevy
1,086
This is a pic while i was building mine. Used 2 truck bags to support what ever weight i wanted. Have DJM lower control arms. Truck front x member is about 4" off the ground.
Sent from my SM-G930P using Tapatalk
