Hey everyone, posting this for my dad. He currently has a truck with a blown LB7 motor, with the ZF-6 manual 6spd. Just trying to figure out how to swap in another motor. We haven't purchased the replacement motor yet, but for only a few extra $'s there is a much lower mileage LBZ available instead of throwing in a higher mileage LB7 (~ 50,000km vs 200,000km), and we're trying to find out if it's worth it.
I assume the LB7 swap will be basically a direct swap, using the old ECM, etc, and just throwing in the new motor?
Now as far as the LBZ swap, I've found a few posts on here that say there are a couple pins you need to swap on the wiring harness as well as adding a couple wires for GMLAN (in addition to the "physical" things like the new gas pedal, etc.). I was just wondering what additional complications there will ve when a ZF-6 is to be used. I know the LBZ's never came with the ZF-6, so is the only real route to use a custom tuner? If so, what unit needs to be purchased, most guys on here seem to be using EFILive?
Thanks in advance for the help!
