LB7 or LLY
Dmax_hromek
Oct 4, 2011
22
Petaluma, CA
Which motor is the better choice for a daily driver? Looking to get at least 500hp and would like to eventually end up with around 800hp. Pros and cons to each motor? Opinions?
FMOS
Hard Up
Nov 19, 2008
352
I'd say either would be fine but my vote goes to the LLY.
To get past 500hp your going to be looking at a turbo change so we can rule out the difference in turbo's between the two motors. I prefer the injectors on the LLY because they dont have issues like the LB7's are known for. The rest of the fuel system is pretty much identical. The motor internals are similar if not identical. The headgaskets suck on both motors, if they havent been blown yet your going to be looking at changing a set once you get past the 500hp mark I'll bet.
My old LLY made something like 619rwhp and that was with a modified fuel pickup, FASS lift pump, HTT turbo, head studs, Suncoast transmission with a precision converter and a shit ton of other support mods but nothing really to call home about. It was tuned with EFI live by myself.
Are you deciding between these two models because you can get one cheaper? Its a lot easier to make 500hp on the LBZ/LMM. For 800hp I would venture to say your getting into the territory of rebuilding the motor with better internals. I'm fairly certain the rods were bent in my LLY after some heavy abuse, it started to smoke when it was cold really badly.
S Phinney
4,008
Quncy, Fl
It is a toss up. Both cost about the same to work on if you are paying for labors. Injectors are cheaper for the lb7 than lly by about a hundred bucks. But labor is more on the lb7. The lly I have is a little quirky compared to the lb7. If I was buying on for driving probably a lbz. If I was buying to race probably a lb7.
Sent from my SCH-I500 using Tapatalk
Noreaster
2,910
Cape Cod,MA
You can make alot more than 500hp with a stock turbo & sounds like you had a bad experience with head gaskets to post a dumb statement like that
