looking to see what everyone has done on their lb7's using a 3" y bridge, what did you do with all of the hard return lines and the fprv valve that bolts to the intake.. obvisously cant move it to much because of the HP lines, is there anything else you can do, or did you just notch out the edge of your 3" tube when you welded it to the y-bridge to clear it?
was thinking about cutting my hard return lines from heads and welding -4an fittings to the ends of them and use braided lines and an fittings..
also considering lbz intake runners and Y-bridge(rebuilding y-bridge a little bit though) what are you doing with all the lines if youve gone this route with the intakes?
thaaanks!
thaaanks!
