New to forum and looking for some advice on my money pit. 2003 2500hd LB7 with 145K. New injectors, new trans, and now a crank sensor, cam sensor code with no start. Cranks for a couple seconds and kills starter. Looked and found lower bail connector on top of engine was open and loose. Refastened bail connector and cleared codes. started up and ran fine for a quick run around the block. This morning same action with no start. kept looking into bail connectors for issue. Need diagram that shows which pins are for what. Thank you to anyone that can help!
