Keyed power under hood
sweetdiesel
That's better
Aug 6, 2006
10,390
52
Thailand
Is there anyplace to tie in for keyed power under the hood?
I know a few spots in the cab,but would prefer under the hood if possible
psyco66
Apr 14, 2008
368
San Mateo, CA
Yes there is a keyed power under the hood. I pulled it from there for my lift pump. just go into the fuse box. I used a fuse tap and pulled power off of there. I can get back to you and let you know what fuse I used later. I am not near my truck.
SIKDMAX
Highway Burnouts!
Sep 14, 2007
4,698
37
Central Coast, Cali
www.sikdmax.com
Many of them on the 99-06 fuse panel. Like John said go into the underhood fuse box. Things like radio, heater, windshield wipers, etc etc. Easy to test for with a test light, then use one of those trick little add a circuits.
SIKDMAX
Highway Burnouts!
Sep 14, 2007
4,698
37
Central Coast, Cali
www.sikdmax.com
05_LLY
Out-A-Time
Aug 7, 2006
1,756
42
Norvelt, PA
I taped the wires under the fuse panel, IIRC the all pink wires are key on power, one is a heavier gauge than all the others, thats the one i used! i used it to power (engage) a relay under hood so anytime i need key on power i have it readily avaliable from the 40amp relay!
sweetdiesel
That's better
Aug 6, 2006
10,390
52
Thailand
i should of said that i need a fairly nice size gauge wire as this is for powering quite a bit of stuff
I will lift the box up and check for a heavy pink wire
Thanks Yall
NelsonDiesel
Formerly StewieTuned
May 8, 2008
896
41
Buena Park, CA
www.NelsonDiesel.com
as mentioned about a relay -
Use one. Tap into a keyed circuit and have it trigger the relay on and have a fatty wire feeding good power to the relay. It will then kick out the fatty power to your new circuits and not draw from the initial tapped into circuit.
Use a fuse too.
05_LLY
Out-A-Time
Aug 7, 2006
1,756
42
Norvelt, PA
Thanks Yall
The wire under the box isnt real heavy, maybe 12ga IIRC but its enough to pull a relay coil in. then i fed the hot side of the relay with a 10Ga wire direct from the battary. 10ga wire and a 40 amp relay will carry quite a bit but you could always step up the wire and relay size!!
Off my relay i run my lift pump, the dual cp3 signal wire, and the flex lite fan signal wire!
Good luck simon!
