Just bought 05 cc duramax, low coolant!!!
erictriche
Dec 19, 2010
11
Hey guys,
just bought my first diesel. I think i learned my first hard lesson too. Coolant system pressurizing and blowing bubbles in bottle test. burps coolant out of res. and now leaking from rear of engine when cold.
taking to dealer tommorrow? 120hp superchips tuner, shift kit on tranny..
probably head gaskets.. replaced cap already no luck.
whitetrash21
put on da damn helmet day
Apr 29, 2008
4,929
Vegas
Headgaskets.
Mine does all of the above except leak outside the block and I have a popped HG. Good luck with it, sorry to hear.
erictriche
Dec 19, 2010
11
upper rad hose has solid pressure.. still has pressure when cold in morning. how much did hg job cost you wes
FMOS
Hard Up
Nov 19, 2008
352
Fort McMurray, Alberta, Canada
If you do it yourself it can be done fairly cheaply in about 20 hours... For me gaskets were about 150-200 a piece and the head studs were 600. Copper washers and O-rings for the injectors totaled about 100 bucks. Head alignment dowels were like 5 dollars. I took the heads to get checked/milled and it was 100 and change. Exhaust gaskets etc was about 80 bucks.
Its just the work that is a pain in the ass. I recommend pulling the motor out of the truck. Or taking the cab off if it is easier. I did it in the truck though and managed to get it done. Just hard working on a lifted truck from outside of the engine bay. Half the time I was laying across the motor or sitting on top of it or working from the wheel well.
whitetrash21
Apr 29, 2008
4,929
Vegas
Same stuff mine has. Like FMOS said, do it yourself. Save some money if your truck isn't under warranty. Just found mine out recently, gonna do it myself when I can get some time.
erictriche
Dec 19, 2010
11
134461: pressure test of cooling system found headgaskets leaking exhaust into cooling systems
quote to repair mine: 57.8 hrs labor to replace headgaskets only
10 hrs because lift and 1.5 for oil change and thermostat. Total charge from CHEVYLAND in shreveport LA was 7462.07
Nice anybody have a shop around shreveport i could use!
TeaBagger2006
Im a Garrett Nut Swinger
May 11, 2008
3,123
15
Bis ND
you see what happens when you mess with LBZ at the strip:D
let me know when youre gonna dive into this llittle project..... i'll help ya:D
madmatt
Apr 12, 2009
1,595
"the mecca"
www.facebook.com
WOW:eek::eek: for that kind of money you could haul/ship the truck to someone who knows what they're doing and still come out a couple grand ahead!! I do them for under half of that all the time with studs and any machine work that may be needed.
paoutdoorsman
Duramax Fan!
Mar 27, 2009
159
South Central PA
Ouch! Sorry to hear.
A quick google search turned up these 3 shops in Shreveport.
John Kemp Diesel Repair Services
7918 Hobbs Dr
Shreveport, LA
318-688-4647
Parsons Auto & Diesel Repair
1014 Mars Boulevard
Shreveport, LA 71107-7132
(318) 677-2551
Shaffer Auto & Diesel Repair
7292 Greenwood Road
Shreveport, LA 71119-8101
(318) 938-9794
erictriche
Dec 19, 2010
11
guy i bought truck from is about to be taken to small claims court
got a mech 4500
still looking
