LML Internals
dmaxvaz
wannabe puller
Nov 22, 2006
1,132
46
METRO DETROIT
all of the lml short block parts *should* interchange with all previous gen dmax short block parts...all of the basic dimensions stayed the same, so i see no reason why you couldnt try some lml pistons in a lb7/lly/lbz/lmm built motor and see how they hold up...
Cr is down a bit too on the lml, i think its now 16.0:1?? Or at least thats what some of the documents said....
the lml is 16:1, but the van engine is 16.8:1. Also, i had a conversation last wk with one of the engineers and he still thinks that the pistons will crack at twice the hp rating.
duratothemax
<--- slippery roads
Aug 28, 2006
7,139
Wyoming
I know this is a million dollar question, but I would be plenty happy if they were as strong or stronger than LB7/LLY pistons...
anything is better than LBZ pistons.
dmaxvaz
wannabe puller
Nov 22, 2006
1,132
46
METRO DETROIT
hopefully! whats nice is they are 16:1 meaning no machining needed during builds
JD4440
<< Lo-Carb Monster
Feb 27, 2009
1,776
Orlinda, TN
But did he hold the same opinion of the LB7/LLY pistons ?
(400+-)x2 is still over 800. The LBZ aren't doing that.
Figure actual HP is around 320 rw. Some most likely went 640 but not many and not for long.
dmaxfireman
'Can do' kind of guy
Apr 8, 2007
2,329
CT
i was informed this afternoon (by somebody who had pulled apart a lml) that lml pistons will not fit lbz rods without machining.
x MadMAX DIESEL
<<<< No Horsepower
Dec 30, 2008
7,535
33
Lexington, Ky
Interesting, though I really don't think any one want to do that.. If you had good pistons, then matched up with the soft LBZ rod I dont see any gain by doing so
