LB7: Installed a LBZ pump in a LB7 and now will not start.
DetailsUnlimited
1,264
Benton, Ar
Done this many times. And have not had this problem before. Did the install. Changed the tune for the bigger pump. All sensors were hooked back up and just cranks. Log shows actual at 26107 and desired at 5800 while cranking. Not sure what is going on there? No leaks, any suggestions?
WVRigrat05
Wound for sound
Jan 1, 2011
3,124
26
French Creek, West Virginia
Sure everything is plugged in right? I did that once on the LLY, I plugged the baro sensor into the fpr and hooked both of their connectors back into themselves. It would start but wouldn't stay running.
DetailsUnlimited
1,264
Benton, Ar
Installed original tune and still not start. Looking at plugs. Any help with this issue would be great as I need to get this guy back on the road.
dirtydmax
<---up shit creek
Sep 1, 2013
1,107
9
47
muskoka,Ont Canada
Check for broken wire at fuel pressure sensor on hp fuel block.its a 3 wire plug and they break right at plug.broke wire there will max rail.No codes?
DetailsUnlimited
1,264
Benton, Ar
Not sure what it was. All plugs were solid. It just started so it had to be rail, fuel block or wire harness connection were the only one I disconnected and reconnected. Thank you to the guys that called and answered on here!
