injector question
03pewterdirtymax
ex ford guy
Oct 16, 2011
26
ok fellas gota quick question. my injectors were done warranty at 90k in 07. truck currently has 141k on it. if my injectors were to fail again what kind of warranty would they fall under? if any? i would imagine that they would fall under the 200k but idk. you guys have any idea??
darkness
1,244
329
vegas
7 years/200k whichever comes first....from when truck was put in service. you are out of warranty :)
03pewterdirtymax
ex ford guy
Oct 16, 2011
26
That's dumb I figured it would atleast have a parts warranty. Like they cover parts and I cover labor or something lol
3,691
248
It sucks that the injectors go out as often as they do, but I have a hard time being mad at GM. As soon as they realized it was a problem they extended the warranty to 7 years / 200k miles. How many vehicles warranty ANYTHING for that long?
When mine go out again, I am probably going to swap to LLY heads and ECU and be done with the issue. Not sure what I would do if I had an 01-02 though.
And x2 on using some sort of lube. I've had good luck with 2 stroke oil or PowerService (whatever is cheaper at the time).
JustinD
Plow Truck
Nov 21, 2008
2,067
41
Tiverton Rhode Island
Injector issue does suck I had all 8 done in 08 under warranty, now about 70k later I'm having injector problems again. Use 2 stroke and be careful not to run the tank too low, I would also go with a filter setup of some sort, Nicktane or a lift pump with filtration.
Heartbeat Hauler
May 5, 2008
19
Morgantown, WV
I would be less mad at GM had it been 200K miles, period. By putting the 7 year time limit on the warranty makes it essentially worthless.....to me at least. Oh well, live and learn....and I have.
Thebigsteamer
Dec 1, 2011
Any thoughts on these injectors?
i pulled the drivers bank out today.
this is what they look like.
Any telltale signs here?
