well i had a bad balance rate on number 1 after the races in AZ and today i replaced number one i have 45% nozzles so i had to swap it over to the new injector well put it in an white smoke at start up was worse and the balance rate was worse i was like wtf?? Took it for a drive and holy shit got down the road a bit an it started knocking and rattling and puking white smoke got it back to the shop then i tore it down again(i had another new injector) and this time i took a know good injector already in number 3 put in number 1 cylinder and put the new injector in cylinder 3 to see if it followed or something was up with cylinder 1(again i swapped the 45% nozzle on to it) and got it together again....
Then started it again white smoke like crazy and balance rate was bad on cylinder 3 so it follows that nozzle so am i correct in thinking the nozzle is bad??? its a extrude hone nozzle two new injectors couldnt be bad outta the box could they?
any input would be nice
