My back driver side injector is leaking again. The first time it leaked, I replaced the copper washer. Any ideas what might be going on?
JC
JC
when you replaced the washer did you clean out the injector bore?
The wear plate is on the head wear the hold down sits and tightens down isn't it? If they are missing it could cause something like that or a defective hold down maybe.
make sure the injector tip is tight make sure it is torqued down to 40 ft lbs
