how is everybody removing the injector cups on the LB7 i need to pull all mine out and re do them. is the GM tool required or is there another company making a tool for this.
Thank You
Thank You
Should just slide out? take the injector and wiggle it in the cup
there is a tool from GM to install and remove them ( same tool ) bit ive never used it
So there is no torque spec for seating the cup? Just use red locktite? The cups dont thread in or press in?
Thank You for all the information so far everyone:hug:
does anybody know of a cheaper place to get the tool from than etool.com?
one side down, one to go.
You have to love when you expext a bucnch of loctite on the cups from the recently done injectors and cups at the local dealer and there is non to be found
problem was in #3 cylinder but none of the cups had any loctite on them
More bad news the farther i dig (this is all on the drivers side)
cylinder # 4 cup was cracked
cylinder 2 had 4 threads holding the injector hold down,
cylinder 2 and 8 the cups were siezed on the injector (big F"in pliers to remove)
Cylinder 6 cup only had one o ring
No locktight on any cups
mismatched bolts on upper valve cover (allens and 12 mm bolts and striped headed allens)
lower valve cover all bolts had striped heads except 3
no cups were salvageable had to replace all 4
valve lash was .030 on the tightest one before dismantle (supposed to be .012)
as you can see i am extreamly pissed and will be having a nice long chat with the mechanic who did the injectors and his boss.
This just goes to show you that if it is an important piece of your truck you just have to get your hands dirty and do it yourself.
