Hey, i have been lurking for couple of months. I have an 01 4dr dually, 130k, automatic, that I just can't get enough of.
Has anyone had a problem when they replaced the fuel pump on and lb7 on the left cylinder head, the return fuel rail that bolts to the back of the cylinder head? There is a banjo fitting on the back of the head that the return line bolts to and on the outside of the head there is another banjo fitting and bolt for the line that runs to the other head. I didn't overtighten those bolts, but found out that it stopped the return of the fuel and raised the return rate and blew off the top of one of the left bank injectors. It seams that the banjo bolt bottoms out and shuts the flow off. Has anyone run into this problem before?
I checked to make sure that they were the correct bolts and they were. There are no washers or spacers on the fitting or bolt except the shoulder made on the bolt and that both bolts were the same length. Any one run into the before?
Thanks Rob
Thanks Rob
