How do i turn the high idle for cold starts off, I dont like it. I want my truck to warm up the slow way. I know its some manuvering with the brake and gas pedal, I just dont remember what.
http://www.kennedydiesel.com/docs/Elevated_Idle_Description_LLY_Duramax.htm
I assume it's the same as an LLY
I didnt even know you could get them without steering wheel controlsNot if you don't have steering wheel controls
I believ you hold the gas pedal to the floor with the engine on run and then stab the brakes 3 times
High idle is good for the engine in my opinion, as it helps it warm up quicker and mine runs much smoother in the cold with the high idle then it does idleing low, I clatter like a 12 valve when it is really cold out and the idle is down as soon as it idles up it seems to calm down a bit.
It's actually "better" for your engine to warm up using high idle.
