Help!!! Fixing to have a blaze in my driveway
Mike
hmmm....
Feb 17, 2007
2,184
San Angelo, TX
Mike L, I am getting a P0872 code continuously. I have checked "E" shift valve repeatedly, and the valve has not been stuck and moves freely each time I checked it. I have replaced E " on/off " shift solenoid and checked to make sure the psm is functional.
Should I check the C1 clutch pack? But then again, 3rd is working?????? I guess if limp mode 3rd is working.
This all came about after reinstalling the transmission after checking the flex plate. All was fine, but just had to do extra work for nothing.
Is there any chance the truck limps to 4th? If I drive the truck in limp mode, the truck rpm's reflect the same rpm's the truck showed while in 4th when the transmission was functional.
Thanks you.
Mike
hmmm....
Feb 17, 2007
2,184
San Angelo, TX
If the truck is limping to 4th, this is the same thing that was happening that caused me to have my transmission rebuilt. Hmm.....
duramaxin14
Just Keeping Up
May 25, 2007
912
Wauchula fl
O i pray someone can shine light on this i have the same exact problem. pulled tranny pan back off put new solenoids in it and still doing it
BIG DIPPER
Nov 6, 2006
205
It is the shift valve guys. I know it is hard to believe as it is free on the bench, but the valve sticks again after the valve body twists from being torqued.
duramaxin14
Just Keeping Up
May 25, 2007
912
Wauchula fl
Big dipper if they are not sticking on the bench then how do u suggest not to get them to stick in the tranny clean the hole that there in or what? Also is the e shift vavle the long rod with the link pin on it that goes to your gear selector?? Also im not trying to be a smart ass so please forgive me if it sounds this way. I am just fed up with this shit and ready to light a macth to the truck.
Mike
hmmm....
Feb 17, 2007
2,184
San Angelo, TX
Kurt, I'll email you a picture from ALLDATA I have downloaded. It will have what you should check for.
BIG DIPPER
Nov 6, 2006
205
It twists when it gets torqued down.....think of honing an engine block and the use of torque plates whil doing it, same thinking applies here.
Actually, it has been claimed as a casting flaw. I have seen some do it and some don't although I now hone the bore on every trans I do.
Mike
hmmm....
Feb 17, 2007
2,184
San Angelo, TX
I have about every tool I don't need, but I wish I had a tool that I could use as a hone in a bore that small. I'll pull the pan and valve body again here in a minute and give it another shot. Thanks for the help, I do appreciate the advice. On one of the last checks, I even swapped the " E " and " D " on/off solenoids. Why is the trans taking off in 4th? Thanks again.
duramaxin14
Just Keeping Up
May 25, 2007
912
Wauchula fl
thanks new lb7 for the email. let me know if the e shit honning deal works out for you because i may be doing the same deal i dont believe the soionid screen would have anything to with it but well see thatnks again man
LB7Diesel
Oh Boy!
Sep 3, 2006
1,355
Melbourne, F.L.
Might try a pencil wraped with some fine grit sand paper..Or grab the scrubby out of the kitchen sink and use the brillo stuff wraped around the pencil fit to size..Kinda like starting a fire Indian style..Just throwing out ideas, I've been drinking too so you might want to come up with your own idea!!
Mike
hmmm....
Feb 17, 2007
2,184
San Angelo, TX
Thanks, I appreciate the thought and idea. I'm up for anything. Guess I'll have to invent a manual valve body for this darn thing. That's an idea :p
15,686
How tight are you guys torquing these things? They should not be any tighter than you can tighten with a nut driver. Valvebody must be clean; your hands must be clean and the valve must be clean. This shit is like surgery. All the bolts on the VB should be hand tight when bolted up to case then all bolts should be torqued on the case. P0872 can also mean a short in wiring harness or pinched wire going to trans.
9,903
149
Mike (new2LB7) as you never took your valve body apart (right?) I would lean towards the harness too. 1 shorted wire or a pin that is bent or moves back in the plug when you plug it in can cause nightmares. You need to push and pull EVERY wire in EVERY plug to ensure this isn't the problem.
I've had it happen to me before in an ecm harness plug once - took forever to find it.
duramaxin14
Just Keeping Up
May 25, 2007
912
Wauchula fl
mike that was my brother on earlier i figure u would no because he was calling u new 2 thanks for the info i will tear the vb down tommorw
Mike
hmmm....
Feb 17, 2007
2,184
San Angelo, TX
Thanks Mike L. I'll keep the tightening technique in mind. I could most definitely be guilty of over torquing the valve body, 109in/lbs is not a lot. Everything is very clean, including my hands and tools. I have gone through the steps, listed for this P0872 code, provided by ALLDATA concerning the shorted wiring. I'm up for anything and will certainly take you advice and use it. Thanks.
Mike
hmmm....
Feb 17, 2007
2,184
San Angelo, TX
Yes, you are right Dale, I started having this trouble before I removed the valve body. I only removed the valve body to go through the trouble shooting steps provided by ALLDATA. I will certainly check the wiring. I checked the plugs when I bypassed the co-pilot wiring and did not find any bent pins, but will recheck.
Thanks Dale.
