help bring up duramax Imperial pids
dieselboy04'
DieselBoy04'
Mar 23, 2008
135
41
Virginia
When I choose "Duramax Imperial" it always says invalid PID selection when I go to record it? Only lately though I don't know what happened?:confused:
you may have to many selected... I think you can only have a set amount and if you go over it that number it wont log...
dieselboy04'
DieselBoy04'
Mar 23, 2008
135
41
Virginia
File-open..."open pid selection",
should be a fair number of options to pick from. Also, you can change them and save your own custom pid selections for later recall. yada yada.
well I think that's what I did... was save a custom pid when I didn't know what I was doing and now I can't get enough info for proper logging... I know I can go in and change it that's not the problem. The problem is which pids should I have selected or basically what's the default selection consist of?
sweetdiesel
That's better
Aug 6, 2006
10,390
53
Thailand
Open Efi and go to help section in there is every thing you need and more on pids and how to select them, how to make custom pids , how to make dashbords line up with corresponding pids
