Head/Intake Manifold Question
SAVAGE77
Nov 20, 2009
78
Just took my heads to the shop to get resurfaced. They took the intakes off. Underneath, not part of the intake, are two threaded holes. I don't have any hardware for them, and they are dusty looking like they've never been used. Are there supposed to be any bolts there? Want to be certain before I put seal the intake up and drop the head on. Thanks!!
3,796
423
I totally can't recall on those two holes, but as for getting the cup off the injector, I've done that before.
If you don't care about the cup, just clamp down on it with a vice. Then grab the injector with a wrench where the hold down normally goes, and try to rotate it. Once it breaks free and spins, it should lift right out.
If you do care about the cup, do the same thing, but with a piece of wood or nylon between the cup and the vice.
That's what worked for me, as I recall.
SAVAGE77
Nov 20, 2009
78
Thanks! I can't see anywhere in all data that they are used either. I appreciate all the help on them I can get though!!
moparkxracer
2,309
33
Out and about
If I remember those holes are not used, when you silicon the intake runners down they are covered. Just put the silicon on the runner and torque them down. From what I have heard some have made a slap hammer to remove the cup. If you use the search on here they show pics and give the lows/Home Depot shopping parts list.
SAVAGE77
Nov 20, 2009
78
Sweet. That's done and torqued. Seems I remember on the driver's side you have to put the back two bolts in before dropping the head on. Is it the same on the passenger's? Also, Is it better to place the alignment dowels on the block side to hold the gasket or the head side? Thanks!
malar24
60
NE Ohio
I used a ziptie to hold the stud in the head while I set it down on the block. You can put the studs in on the passenger side once you set it on the block. You will once the dowel pins in the block to hold the gasket in place. Hope this helps ya out.
SAVAGE77
Nov 20, 2009
78
Damn, I just noticed Merchant's kit comes with locktite 271 but everyone says use 272 to seal the injector cups.. Any advice? Thanks!
