I know that there are three different thicknesses for the Dmax head gaskets.
I was told by a stealer parts guy that some trucks have different thickness gaskets from one side to another.
My first question is why would GM need to have different thickness gaskets on the same engine?
Are the machine tolerances that bad that they are balancing cylinder volume with gaskets?
My second question is which thickness would you want to use on a rebuild, or would you want to keep the same thickness gasket as what came out?
Off the top of my head, for a rebuild I would think you would want to use the thinnest gasket, so you would have less chance of a blow out at elevated boost pressures.
