How much would a Head Gasket job for an LB7 cost in a general Ball park? I think they're shot and I'm just trying to get an idea. IF there was more damage how much would an entire replacment engine cost?
Just need to know if the heads can be resurfaced?
Well went out and checked the oil. about 2 inches overfull but can't smell the coolant, maybe oil smell is stronger than coolant? Still had pressure under the overflow cap. Shut the truck off friday night at about 11pm and it's sat since then. Have not tried starting it. Should I try run it up on a trailer or have it towed?
Are you sure its not fuel in the oil? Usually don't get coolant in the oil on a Duramax. Usually bad head gaskets will leak externally or put compression in the cooling system. Did they change the oil after the injector job?
