I have been having issues with an lbz.. Truck is a cab and chassis truck, has 2 fuel tanks.. I replaced the cp3 pump and wile watching efi live, if i pump the primer up till its hard. And try to start the truck, it makes 900 to 1000 psi of rail pressure, then after a cranking it over a few times the truck makes less and less rail pressure till it only makes 150 psi and at that point the batterys are about dead... A few days ago i removed the return line and took an old return line and made it so i could isolate each injector return in to its own bottel... I then pumped up the primer untill hard and left to go to the store(90 mins or so).. When i returned i noticed a small amount of fuel in cylinder #6 return bottle.. So i then changed it out for a different bottel that wasnt use.. I think pumped the primer again, and turned the key on till the truck timed itself out.. I used a medicine spoon i bought from drugmart to messure in ml because I couldn't find a graduated cylinder or anything a long that line.. I tried to test 4 to 5 times.. And i got anywhere from 6ml to 9.. My question are, am i testing correct? I onow that i dont have the $300 test kit.. And i know lbz are supposed to be reliable as far as injectors, has anyone had to replace them all in one bank?
