Quick update got the trans out tonight tomorrow afternoon I will pull it apart.
Sent from my SAMSUNG-SM-G890A using Tapatalk
I don't recall having a steel spacer. There was the outer planetary ring inside the clutch pack then the planetary with the plastic washer the single clutch that got messed up was the one closest to the c2 drum like it had slid forward and off of the outer planetary ring.Where is the .100 steel spacer that belongs under the plastic washer? That is why your top C3 clutch was torn up.
