LB7: fuel rail fittings
MAXPWR
Diesel Junkie
Mar 13, 2008
57
Blair Nebraska
OK guys! Pulled the fuel rail fittings, I was told that they were different sizes. Mine are the same size (stock) 7/64 in size. Mod sizes I thought were 1/8-9/64(.125)driver and 1/16 (.060) pass. So what if anything do I do?? Drivers is close to the mod size and my pass is already larger!
SDP
AKA Dmax15
Dec 20, 2008
261
Port Angeles, WA
Mine were the same, I think the LB7 rails are individually fed so they use the same size holes in the fittings. I ported mine out to 9/64 on both sides since I had them out, not sure if it made a difference though.
2500HeavyDuty
Book 'em, Danno!
Feb 14, 2008
2,209
Katy, Tx
www.myspace.com
the stock vs ppe i could not tell a difference by looking at it, but when i tried shoving drill bits into it at the hardware store the ppe is bigger than stock.
i got one ppe one and a modded stock one thats been ported out to .125
MAXPWR
Diesel Junkie
Mar 13, 2008
57
Blair Nebraska
I think I'll just stick them back in. And plug the blow off,like 2500HD showed. So far my rail pressure hasn't dropped but I still haven't loaded up one of my bigger tune :D Thanks guys!
paint94979
Beer Nazi
Sep 18, 2006
11,714
Thats interesting the PPE Fuel Fitting I got was substantially larger in diameter than my stock piece.
sweetdiesel
That's better
Aug 6, 2006
10,390
51
Thailand
IIRC LLY and LB7's are different sizes. Someone correct me if I'm wrong.
They are different:) BUT lb7 are 2 piece and still have a restriction.
LLY are 1 piece fittings basically both can be drilled out
sweetdiesel
That's better
Aug 6, 2006
10,390
51
Thailand
Ya each rail is the same size:) and they Y off to each rail unlike a lly
MAXPWR
Diesel Junkie
Mar 13, 2008
57
Blair Nebraska
Looked again and found what you where talking about the two pieces. So we drill the bullet looking piece out to 1/8 drive and the pass to a 1/16?? The driver one is smaller than 1/16 right now, that pretty big! I just want to make sure I have this right before I start drillling, I don't think these would be cheap or easy to get from the stealer if I mess one up! I asked Kat to post the pics for me and I will put them in my pics as well
MMLMM
Tunergeek
Mar 2, 2008
4,086
42
Reno, NV
www.dyncal.com
LLY, LBZ, LMM drill driver side to .090 (actually a 2.3mm bit is perfect for this), and if you want to do the pass side, go .060
LB7 are both the same size in each rail and you really shouldn't bother porting them. I think they are pretty open as it is.
sweetdiesel
That's better
Aug 6, 2006
10,390
51
Thailand
Why not drill both Mike?
The rail fittings are a nice size ID , Its what is behind the fitting that is the restriction;)
Does any of it really make a difference:confused: I still drill em out:D
Kat
Wicked Witch of the West
Aug 2, 2006
17,899
13
59
Norco, CA
Here are Dave's pic's
