It should be what the ECM commands.
If he can't read desired and actual, he won't be able to diagnose anything. Unless he has one of those gauges that T in to the factory sensor.Yes but I think he may be asking to diagnose a issue and he may not have the tools to able to see whats commanded/actual.
From the stock tunes I have on hand, here are the pressures you should see for a HOT engine (it will be higher while warming up):
LB7 - 35 MPa (5,076 psi)
LLY - 32 MPa (4,641 psi)
LBZ - 30 MPa (4,351 psi)
LMM - 30 MPa (4,351 psi)
LML - Lol, wish I had a LML tune in EFILive...
4500-5500 is mine onna gauge.
over 6k it lopes a little.
For a quick test, it would be fine. However, diesel will destroy seals designed for gas, and it will start leaking quickly (within a week, most likely).I don't see any reason why a gas one wouldn't work.
