03 dmax lb7
modded lbz pump/reg...used came off a running truck
gauges
rail current tuned correctly
lift pump disconnected
aftermarket radio disconnected
start truck and the fuel pressure is at 27k..just like if you unplugged it ..
running wide open
changed fpr ,retuned it ,changed ECM,checked all wires to and from ecm to fpr ,tested them with ohms meter all checks out..ran new grounds from battery to body and battery to motor
truck has hurt some injectors because of high fuel pressure ..going to change them ,but first want to get fp under control before install of new sticks so we don't hurt them also ,,any help would be great guys thanks..
gauges
running wide open
